itfactory Posted November 3, 2008 Share Posted November 3, 2008 This is my first Installation using Prestashop. Don't know much about PHP and E-commerce. I was following Installation document and try to setup on my own. I'm stuck now with second step.Keep saying "System and permissions" If I say "NEXT" not doing anything. I believe I have set permission to required folder but not sure If I did correctly to database stuff. My current webhost support Apache ver. 2.2.8 (Unix) PHP version 5.2.* MySQL ver. 5.0.45-community.Please advice If I'm missing anything ? Link to comment Share on other sites More sharing options...
Bruno Leveque Posted November 3, 2008 Share Posted November 3, 2008 Hi,Did you click on refresh after setting right permissions? Link to comment Share on other sites More sharing options...
itfactory Posted November 3, 2008 Author Share Posted November 3, 2008 yes, I did but nothing happens Link to comment Share on other sites More sharing options...
pleja2929 Posted August 28, 2010 Share Posted August 28, 2010 Hi,Did you solved this problem?Now I face same problem as you.Could you please provide the way to solve? Link to comment Share on other sites More sharing options...
crazydeals Posted August 28, 2010 Share Posted August 28, 2010 You will need to chmod the permission of folders to 777. This can be done by FTPing to your webhost server, right click on the folder and click properties.Write permissions on folders (do not apply recursively/to subfolders):/config/upload/download/tools/smarty/compileWrite permissions on folders and subfolders/recursively:/img/mails/modules/themes/default/lang/translationsI have attached a screenshot for you. You will just need to tick all the boxes. Link to comment Share on other sites More sharing options...
