sticcino Posted July 8, 2016 Share Posted July 8, 2016 Hi Everyone, is there a built in module to display an image in the body so that when clicked it will goto the item/category and.. can 2 be displayed side by side Example: |-------------------------Image/Item 1------------------------| |--------Image/Item 2--------||--------Image/Item 3---------| would you use the CMS module then use the positions to put image 2 and image 3 next to each other?. I'm using the rotator banner, but these are to be static Thanks, Johnny Link to comment Share on other sites More sharing options...
shokinro Posted July 9, 2016 Share Posted July 9, 2016 If it is banner image is fixed and links are also fixed, it is easy to just add 3 links to the location you wanted. But it will be depend on the location of your banners and also the theme design. Below is just a example, it is not tested so it may not work perfectly with your theme. <div class="row"> <a href="you URL"><img class="img-responsive" src="your image url"></a> </div> <div class="row"> <div class="col-lg-6 col-sm-6 col-md-6 col-xs-6"> <a href="you URL"><img class="img-responsive" src="your image url"></a> </div> <div class="col-lg-6 col-sm-6 col-md-6 col-xs-6"> <a href="you URL"><img class="img-responsive" src="your image url"></a> </div> </div> Link to comment Share on other sites More sharing options...
sticcino Posted July 9, 2016 Author Share Posted July 9, 2016 thanks for the info!, i just took a look at the PS demo site, actually i want the display like it has with the rotating banner, and the 2 static items next to it, just have to remember what I modules I disabled to remove those 2 static items next the rotating banner Link to comment Share on other sites More sharing options...
shokinro Posted July 9, 2016 Share Posted July 9, 2016 PrestaShop has 2 modules related to advertising. not sure which one you are referring, you may also consider to use those 2 existing modules. blockadvertising blockbanner Link to comment Share on other sites More sharing options...
sticcino Posted July 9, 2016 Author Share Posted July 9, 2016 Thanks, those did the job. Link to comment Share on other sites More sharing options...
shokinro Posted July 9, 2016 Share Posted July 9, 2016 glad it worked for you. thanks for feedback. Link to comment Share on other sites More sharing options...
