Problem with login to Admin Panel and a few problems more.
Hi!
I have some problems with login to Panel Admin. After logging I'm getting 404 error and I have to cut a part of the link to get into panel.
.../admin/&token=da85c866dbfe77f95d81cf1f579a7c4a
Then, when I'm in I got a message: Controller not found. But it's only after logging in.
Second problem...
I have changed a sequence of admin menu. Admin Dashboard landed in the end of list. I tried to restore that, but even if system shows me "It's done successfully" it's still on same position.
Third problem...
In admin panel when I click on name of the store I'm getting 404 Error.
I hope that one good soul will find a solution and will help me.
Hi!
This is not how the admin link should look like. First: didn't you change admin to anything else with a prefix or suffix?
The link should look like
../admin123456/index.php?controller=AdminDashboard&token=9f67aef2750b58bd27035ea88418fbc2
admin123456 stands for your individual admin folder name after renaming the admin folder.
Second problem...
What did you change? What do you mean by "change a sequence of the admin menu"?
Edited by prestamax (see edit history)
If files are not corrupt, they might be now a mistake in the database..an error might have occured when you were moving the position in the menu. What I'd suggest is backing up the existing prefix_tab tables that are connected with tabs in BackOffice. Delete them and replace them with those from a fresh instalation.
