ysco Posted September 19, 2009 Share Posted September 19, 2009 Hello all,I have a serious problem here and i don`t know how to solve it, i spend many days on my shop and now i discovered this major fault.I attached some pictures to explain it more clearer, i hope that someone have a solution for this as the shop is not working correct this way.SSL enabled ->> The stock in products page in front office doesn`t work.SSL disabled ->> The stock in products page in front office works.Btw i have 1.2.2.0 installed now but i also have had it on 1.2.4.0 so the problems lays somewhere else.I have a private SSL certificate installed.Thanks in advance..ysco.. Link to comment Share on other sites More sharing options...
ysco Posted September 19, 2009 Author Share Posted September 19, 2009 Nobody ???ysco.. Link to comment Share on other sites More sharing options...
ysco Posted September 20, 2009 Author Share Posted September 20, 2009 There is a fault in init.phpIf i change one line in the init.php to https and then set in presta back-office the setting to 1.1 compatible to no then it all works.Only then if you go for example to categories then it will go in https instead off http.Normaly if you go to create account or payments then the https comes in, but now only the homepage screen is http and all other is https.I think that if the code can be adjusted more then it could work the way it should be, don`t know which other lines to adjust to make it work the it was.Maybe someone knows what lines to edit so that ssl only is used when you create account and payments.For now it works this way but i hope for a better sollutionysco.. Link to comment Share on other sites More sharing options...
