Mediacom87 1,331 Posted May 10, 2016 Posted May 10, 2016 Hi, Here is our new module that will allow you finally manage ALT tags for your images. On PrestaShop 1.6 we can define an ALT tag to each product image loading, you can not edit them later to improve its SEO. PrestaShop 1.5, it is worse, we can not define ALT tag much less editing. So this module just solve this problem by also allowing you to manage the meta tags of the product concerned by the images, just to save time.You can also enjoy an automatic generation of the tag taking into account the color variations for ALT tags.Discover this module on his demo to understand its operation and of course the module is downloaded PrestaToolBox DEMONSTRATION demo@demo.com / demodemo Share this post Link to post Share on other sites
nicoX 12 Posted April 22, 2017 Posted April 22, 2017 Can you fill in tags for differnt languages in the same field? And should you use a-dash in the tags? Will this help in Google Images, when someone searches for a name and you have this name in your image tag? Share this post Link to post Share on other sites
Mediacom87 1,331 Posted April 23, 2017 Posted April 23, 2017 Hi, like you can see in screenshots you have a filed by language. yes for dash of course it's a better thing for your SEO. Share this post Link to post Share on other sites
Clay7 2 Posted August 2, 2017 Posted August 2, 2017 Hi, I'm looking for a module where I can edit the ALT tags of images in the product description. I have a lot of images not only in the slider, but also in the description of the product. Is this possible with your module? As far as I could see from the demo, it is not? Do you know if it exists? This would be really helpful. Share this post Link to post Share on other sites
Mediacom87 1,331 Posted August 2, 2017 Posted August 2, 2017 Hi, my module can't help you and i don't think you can reach any module to do it. Only one solution, do it manually. And, just for me, i think it's a badly idea to put pictures in description. Share this post Link to post Share on other sites
Clay7 2 Posted August 3, 2017 Posted August 3, 2017 What? It's a bad idea to put pictures in description? Why would that be? If for example you are talking about the designer of the product you are selling, it is always nice to put in a picture if him/her. Or even video. It increases conversions, and people like images. I don't see why it would be a bad idea at all. Share this post Link to post Share on other sites
Mediacom87 1,331 Posted August 21, 2017 Posted August 21, 2017 Version 1.3.1 bug correction 1 Share this post Link to post Share on other sites
nicoX 12 Posted September 10, 2017 Posted September 10, 2017 Will this improve Google ranking or make images more accessible in a Google Image search? Where can I see my current tags for my images? Share this post Link to post Share on other sites
Mediacom87 1,331 Posted September 10, 2017 Posted September 10, 2017 Hi, Will this improve Google ranking or make images more accessible in a Google Image search? this module help both (ranking and image search). Where can I see my current tags for my images? Directly on your site on each images in ALT. on this exemple the ALT tag is empty and it's not googd. <img alt="" src="https://domain.tld/image.jpg"> Share this post Link to post Share on other sites
nicoX 12 Posted September 10, 2017 Posted September 10, 2017 (edited) Hi, this module help both (ranking and image search). Directly on your site on each images in ALT. on this exemple the ALT tag is empty and it's not googd. <img alt="" src="https://domain.tld/image.jpg"> Can you be more specific where to look. Is it in Inspect> Elements Can't find any info there. Edited September 10, 2017 by nicoX (see edit history) Share this post Link to post Share on other sites
Mediacom87 1,331 Posted September 10, 2017 Posted September 10, 2017 This is a default html code to insert any image. any else my module help you to work on products without any ALT tag difine very quickly because you can configure this module to give you the list of product only without seo tag defined. Share this post Link to post Share on other sites
nicoX 12 Posted September 10, 2017 Posted September 10, 2017 I see if you hoover over an image, what's displayed there is your tag. Share this post Link to post Share on other sites
nicoX 12 Posted September 12, 2017 Posted September 12, 2017 So I knew it, I changed the alt tags and now my images in the image box are gone with the error message:Notice: Undefined variable: html in /home/*/public_html/modules/tabimages/tabimages.php on line 191 Share this post Link to post Share on other sites
Mediacom87 1,331 Posted September 12, 2017 Posted September 12, 2017 So I knew it, I changed the alt tags and now my images in the image box are gone with the error message: Notice: Undefined variable: html in /home/*/public_html/modules/tabimages/tabimages.php on line 191 I don't know this module i can't help you on it. Share this post Link to post Share on other sites
nicoX 12 Posted September 12, 2017 Posted September 12, 2017 We created this module, it's similar to Prestashop image viewer, but we added tabs to it, to separate our colors. Share this post Link to post Share on other sites
Mediacom87 1,331 Posted September 12, 2017 Posted September 12, 2017 We created this module, it's similar to Prestashop image viewer, but we added tabs to it, to separate our colors. if you need help on your module you need to create a specific topic. Share this post Link to post Share on other sites
Mediacom87 1,331 Posted December 13, 2018 Posted December 13, 2018 1.6.0 - 12/11/2018 Adds ALT tag management directly on the product configuration page. Update RiotJS 1.5.0 - 10/08/2018 Adaptation of the source code to bypass some server caches Improvement and update of some code pieces 1.4.0 - 05/11/2018 Add css correction for PrestaShop 1.7 Update RiotJS and PrestUI Clean fontawesome for PrestaShop 1.5 Add more tabs to get more informations Share this post Link to post Share on other sites
Mediacom87 1,331 Posted March 2, 2019 Posted March 2, 2019 1.6.1 - 03/02/2019 Fixed a bug on accented characters Fixed a CSS bug on the DataTable library Share this post Link to post Share on other sites
