Stefanoz
Help with module “Products Category” (Products in same category)
Dear Friends,
Firstly Happy new Year!2010!
I need help with this module:
1. By default this module (“Products Category” – Products in same category) is positioned above MORE INFO on produts page. Does anyone know how to position it below more info page? So now when you click on product you have on the top image and blocks with short description and price on right top. below that is “In the same category” block and last one is more info. I would like to change position of last two. Anyone?
2. How to resize the pictures in this module?From global.css? Which voice?
Best regards
16506_RfsipyTk63TorMEoTjuN_t
Share this post
Link to post
I need an answer for your first question too. Any help?
For the images you can play with them in Admin Panel/preferences/image.
Share this post
Link to post
First problem solution:
1. To change place, edit product.tpl under /themes/prestashop/product.tpl
2. Find this
{$HOOK_PRODUCT_FOOTER}
, line nearly 326.
3. Cut it, and past it to line nearly 390 after this codes
   {/if}
   {$HOOK_PRODUCT_TAB_CONTENT}
{/if}
{Code here}
Second problem solution:
1. Edit productscategory.tpl under /modules/productscategory/productscategory.tpl
2. find this line 15
getImageLink($categoryProduct.link_rewrite, $categoryProduct.id_image, 'medium')}" alt="{$categoryProduct.name|htmlspecialchars}" />
3. Add width="" height="" between codes like that:
getImageLink($categoryProduct.link_rewrite, $categoryProduct.id_image, 'medium')}" alt="{$categoryProduct.name|htmlspecialchars}" width="number here" height="number here"/>
it will be good when decrease image size.
But if you want to increase image size you can change word "medium" to another image name, like "home", "large" etc
I hope it will solve your problem
Share this post
Link to post
I have the same problem, but on 1.6.0.9 version. Can any body help? I need to change "product in the same category" image size. Solution described above not for my version.
Edited by Dzinyna (see edit history)
Share this post
Link to post
Guest
Important Information
