brave200 Posted February 6, 2014 Share Posted February 6, 2014 (edited) Hello: Can someone help me to figure out where in the Global.css I can make the font size to be 12px in the "More Info" description area for my product listings? Is there a similar setting for the "Comments" as well? Below is my example page I'm working with. I checked in firebug and it appears the current font settings are: font: 11px/14px Arial,Verdana,sans-serif;} being inherited from body#product.product I'd like to insert a new font size to override this inherited size for that section only. Thanks again for any suggestions!! http://www.nesgamestore.com/nintendo-nes/8-teenage-mutant-ninja-turtles.html Edited February 6, 2014 by vekia (see edit history) Link to comment Share on other sites More sharing options...
Alex Simonchik BelVG Posted February 6, 2014 Share Posted February 6, 2014 Hi, Are you want increase font-size? I suggest you change css with it: #more_info_sheets, #product_comments_block_tab { font-size: 12px; } Regards Link to comment Share on other sites More sharing options...
Tobiasz Posted February 6, 2014 Share Posted February 6, 2014 You will change both at the time just changing the class: .idTabs a Link to comment Share on other sites More sharing options...
vekia Posted February 6, 2014 Share Posted February 6, 2014 you can also change it in each product description field, just use other font size Link to comment Share on other sites More sharing options...
brave200 Posted February 6, 2014 Author Share Posted February 6, 2014 Got it figured out thanks to all your wonderful suggestions! Thanks so much! Link to comment Share on other sites More sharing options...
vekia Posted February 6, 2014 Share Posted February 6, 2014 hello i see that you marked Alex answer as a solution here, so i suppose that you used his method. am i right? Link to comment Share on other sites More sharing options...
brave200 Posted February 6, 2014 Author Share Posted February 6, 2014 Yes, I was specifically looking for a CSS setting to handle the font size for the product details etc. Link to comment Share on other sites More sharing options...
vekia Posted February 6, 2014 Share Posted February 6, 2014 thank you for clarification now i can go ahead and mark whole topic as solved. with regards, Milos Link to comment Share on other sites More sharing options...
