paulmoz Posted February 4, 2013 Share Posted February 4, 2013 (edited) Hi, I have a bug or data issue with Prestashop 1.5.3 I have 7432 products. All the products are uploaded using the Magnetic One Store manager for Prestashop. When I re-build the entire index using the back office of Prestashop, there is a problem. Only 559 products of the 7432 products index successfully. If I click add remaning products – nothing happens. As a result – I have used the Magnetic One store manager to re-buld the index. The result is that all the products show as indexed, however in the quick search box on the front of the website – when I search for items, it is clear that a great deal of the products are missing. (It has however added more than the 559 that the back office of prestashop indexed) I know the missing products are stored within the SQL database as when I search for the same product in the back office – the products are referenced straight away. I have spent around 80 hours trawling the forums for fixes etc and nothing works. I need help for a system desperately! Can anybody help please? Any ideas? Edited February 4, 2013 by paulmoz (see edit history) Link to comment Share on other sites More sharing options...
benjamin utterback Posted February 4, 2013 Share Posted February 4, 2013 HI PaulMoz, have you tried uploading around 600 products at a time? It could be a memory issue uploading all the products at one time. Link to comment Share on other sites More sharing options...
Tomin Posted February 5, 2013 Share Posted February 5, 2013 Have same problem with ps1.5.3.1. If I search XXXXX, got only 6 products of 30. if I search XXXXy, I got all products i have. Same problem I have in BO search. Index isnt helping - 190 products from 191 indexed and thats all. All products added manually Link to comment Share on other sites More sharing options...
bidjoubob Posted March 27, 2013 Share Posted March 27, 2013 I have the same problem on prestashop 1.5.2 Multi-shop, some shops have 150/360 indexed products and some shops have 100% indexed products. Did you find a solution? Link to comment Share on other sites More sharing options...
